Posted by gbs on January 20, 2013 at 19:25:08 from (71.51.250.1):
In Reply to: 966 tach not working posted by Tristan in MN on January 19, 2013 at 18:22:49:
if it's an electric gauge check for voltage,one terminal should have 12 volts the other goes to sending unit,if it has voltage ground the one to the sender momentarily see if the guage works if it doesn't gauge is bad, if it does ground the wire at the sender momentarily if it works sender is bad if it doesn't wire is the problem,as for the tach unscrew the tach cable form the tach try turning cable with your fingers if it turns your your drive is damaged or the cable square end that fits the drive is rounded off or cable is broken,if it won't turn start engine while it's disconnected from the tach to see if it turns also make sure the square end that goes into the tach isn't rounded off, you should be able to spin the drive end of the tach in the direction it turns and get it to move if its working
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
