Posted by Tom Fleming on January 24, 2013 at 03:48:55 from (67.20.233.75):
In Reply to: C113 heads posted by Mr farmall on January 22, 2013 at 09:19:25:
Simple thing to do is check the head with a machinist's rule or similar flat, straight edge. If you don't have one, have your local machine shop check it out for you. As Gene has suggested, have it re-surfaced if in doubt. it does not cost that much, and eliminates any question on warping. Also, having it magnafluxed is not a bad investment either.
If the head is NOT warped, install the following way.
1.) Block and head mating sufaces need to be clean, down to bright metal.
2.) coat both block and head with a LIGHT coating of the sealer of your choice, and both sides of the head gasket. LIGHT coat, just covering each surface. I prefer the Permatex Copper coat, but everyone has different opinions and preferences.
3.) install gasket and head. torque head down incrementally, using tightening sequence. As previously noted, the torque specs have been upped from 60 lbs. to 80 lbs.
4.) start engine. Bring up to operating temperature. Shut engine off, and while still warm, re-torque head.
5.) Enjoy your new, non-leaking head gasket.
Other's may have a different technique, but this works for me consistently......
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
