Thank you very much for the detailed advice. I tried putting the input shaft in place but I found that there was still about the same amount of play on the main shaft since there was only one bearing on each shaft that was anchored in the housing. I went ahead and put the TA back in the housing and got it moved back over by the tractor and tomorrow I will put it in place and see what the pattern is. I have not been able to find a way to remove the bull gears or the bull pinion carriers separately on the 300, I seem to have to unbolt the carrier, slide the axle out of the bull gear and then rotate the carrier toward the front of the tractor so I can lift the bull gear out and then slide the carrier out. On the Hs I have had apart I could remove the axle and then roll the bull gear back to allow the carrier to slide out, but there doesn't seem to be room on the 300. Zach
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
