Posted by pete 23 on January 30, 2013 at 16:48:11 from (74.32.229.189):
In Reply to: 706 gov. posted by farm-al on January 30, 2013 at 13:24:33:
Probably a worn thrust bearing. They have to be really good to work properly. Weights and pins of course have to be in good shape but even new they are not really tight. Link from governor to carb has to be set properly, throttle wide open, butterfly on carb wide open, adjust clevis to just that length, loose pin, no pressure. Bumper spring has to be firm on fork to work. Adjust screw in so no surge at mid rpm but still able to idle way down slow. The carb bushing and shaft also wear bad in those . Also, make sure the nut on end of shaft is tight as there is no key driving the gov shaft. I have seen them get pretty wild when that nut was not tight.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
