Looseness of the Unloader valve is not an issue as you say that dead ending the auxiliary valve has no effect on the slow lift!!
I think the issue lies elsewhere but ideally need the pressure test!!
Dead ending the aux valve during lift, rules out all problems in the Unloader and flow control valve assy if there is no change to rate of lift ??
While you have unit on the bench remove the union and check the flow control piston and its spring?? This piston (only) is matched to the valve body and could give slow lift, but if it was responsible for your issue the lift would speed up when the aux valve was dead ended!!
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
