Posted by screwstick on February 04, 2013 at 06:23:44 from (174.24.55.76):
In Reply to: cub trans posted by Little Red on February 04, 2013 at 04:58:10:
It's not too bad. Probably an hour to change both.
Pull the shifter cover. Shift one side back, then pull the bolt out of the fork. Place a rag over the poppet ball hole in the top front of the case. Grab the rail with a vice grip pliers, and continue to slide the rail backwards into the rear of the case. The rag will prevent the poppet ball from launching across the room. Continue to slide the rail back until you can slip the fork off the end and out of the transmission. Repeat for the other side (if necessary).
Reinstall in reverse and when you get ready to slip the rail back into the front guide, ensure the spring is seated down in its holder, then place the poppet ball on top of the spring. With a long skinny punch, push down on the poppet ball as you slide the rail forward till it engages the detents. Reposition the fork and reinstall its bolt. Repeat for the other side (if necessary) and replace the shifter cover.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
