Posted by gene bender on February 09, 2013 at 03:08:25 from (67.55.226.151):
In Reply to: Brakes on Super A posted by nh8260 on February 08, 2013 at 21:07:22:
Remove the final drives and the bands are rite there. I remove the wheel then use a cherry picker to remove the final as its heavy. Important to have the chassis secured to keep it secure. You will want a cherry picker as the drivers whell has the cast center and is very heavy.If the seals are leaking the outer ones can be replaced by removing the drum and taking the diff shaft out thru by removing the plate on the final.. Mite also be a good time to replace the lube in the final by removing the bottom housing on the final then replace with 90wt thru the plug located at the bottom of the finaljust above the pan you removed to replace the lube.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
