Posted by pete 23 on February 10, 2013 at 20:37:19 from (74.47.40.242):
In Reply to: 706 steering wheel posted by Farmall-h on February 10, 2013 at 18:23:35:
Supposed to be a nut holding wheel on. Then two 1/4 inch or 5/16th inch fine threaded tapped holes for puller. The best puller I ever found, and I have a regular wheel puller, is a half inch thich piece of iron, about 1 1/2 in wide,just long enough to fit inside of wheel. Drill two holes the distance holes in wheel are apart. Now, those threads will strip real easy so get a bolt long enough to go through the iron and bottom in threads. Add washers under bolt head as needed to accomplish that. Tighten bolts cautiously, tap gently on iron over shaft,add thin washers and continue. Use penetrating oil on shaft. Pulled many a wheel that way rusty and new.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
