Re: i6 transmission gears in m
Posted by D Slater on February 13, 2013 at 03:43:34 from (184.15.14.56):
In Reply to: i6 transmission gears in m posted by zanslastclu on February 12, 2013 at 15:53:18:
I-6 used a different ratio constant mesh gears that turn the countershaft faster compared to a M or W-6. PTO turns faster than 540. Ring and pinion Ratio the same as W-6. Some had low low first gear. I-6 4th and 5th sliding gear won't mesh with a M input shaft for 5th gear. will only mesh with a I-6 input shaft. If you don't care about the pto speed, you may be able to use the I-6 transmission gears with the slow speed low in a M and end up with a speed in first near a regular M and faster speeds between 1 and 5.
Never tried myself due to parts being hard to come by for a I-6.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
