Posted by pete 23 on February 22, 2013 at 15:31:50 from (74.47.40.242):
In Reply to: 404 distributor posted by RLO on February 22, 2013 at 14:16:44:
If you are not getting spark to plugs, but getting spark from the coil wire the points are not your problem. It is in the cap and or rotor. If the plug wires are on wrong it may not run but it will still spark at the plugs. The wires can and may have been put on in different orientation as a battery ign unit can be put on any way and timed accordingly. Pull number one spark plug, turn engine by hand until you feel compression on number on cyl, turn until piston is at top or align tdc mark if you can find it, and then install plug wires to align with rotor. Firing order is l 3 4 2 looking at the cap from the rear, side wires plug in they go clockwise. The cover over points can stick bad. Have to get ahold of the two ears and try. Even if you do break it they will run fine until you can find another one.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
