Posted by Skaning on February 23, 2013 at 19:48:41 from (184.21.242.202):
In Reply to: F20 water in oil posted by Daninsc on February 22, 2013 at 15:53:28:
The rings at the base of the sleeves are a good suspect here. The problem though may actually be the sleeves. The seal area is at the bottom of the block and all of the crud, rust mainly piles up in that area and stays wet. Results in a heavy corrosion ring around the sleeve just above the seal. In time it will work it's way down to the seal surface on the sleeve. It's a real problem with older southern tractors where they never used antifreeze or corrosion inhibitors.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
