Re: ? remove rod that goes through clutch+brake pedal?
Posted by pete 23 on February 28, 2013 at 17:31:41 from (74.47.40.242):
In Reply to: ? remove rod that goes through clutch+brake pedal? posted by Aaron909090 on February 28, 2013 at 09:26:35:
Guess I didn't explain myself clearly. There is a notch in the shaft so the ring gear will not rub against the shaft. You have to get the ring gear out of the way to remove the shaft. Last year I had a clutch pedal rebushed but shaft was only wore a little so got by ok. If seals are leaking you can dig them out and replace with shaft in place. If you must take shaft out, you will have to at least take the right side differential support cage out so diff can be moved back a bit, and that will require considerable tear down. The diff support cage will not come out without removing the bull gear.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
