Posted by realolman on March 03, 2013 at 12:10:42 from (74.98.26.30):
In Reply to: No spark on points posted by William Tant on March 03, 2013 at 11:45:12:
William Tant said: (quoted from post at 12:45:12 03/03/13) Checked for voltage with points close and there is none and none on point plate. So guess ground is good. With the moveable point open I have voltage on it,side of distributor, and both sides of coil. But still no spark when it closes and open against fixed point. Real puzzling!
From your description right there it sounds like the low voltage side of the coil is good.
I think disconnect your points from the coil and replace that with a piece of wire connected to nothing... connect the other small screw on the coil to the battery terminal that is NOT connected to the frame.
disconnect the wire from the distributor and arrange it so that it would spark against the frame if the coil were good... then touch the wire you connected in place of the points to a good clean shiny place on the frame momentarily.
you should get a good spark on the wire that was on the distributor when you do that. If you don't something is wrong with the coil... or possibly the wire from the coil to the distributor.
Here's another thing that I'm not sure iI'm going to be able to explain... The switch on my tractor was "twisted" in the housing so that when the key was turned to crank the engine, there was no voltage on the ignition coil etc. until the key was released. don't know if your tractor has a key switch like that or not.
This post was edited by realolman at 12:47:28 03/03/13 9 times.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
