Posted by IH fan on March 03, 2013 at 14:58:51 from (108.220.169.138):
In Reply to: Gresen 3 Spool Valve posted by IAtractorKid on March 03, 2013 at 11:39:33:
I'd say the set-up on the left side of the valve is the system relief valve andit looks like it's adjustable, probably only within a narrow range, most likey can be varied 500-1000 psi, for example between 1000 or 1500 and 2000psi. Only way to tell for sure is to deadhead a valve, operate that valve fully one way and read a pressure guage on the inlet. If it had a pre-set relief, it would look more like a hex plug with the model # and pressure stamped in it.
3/4" or -12 should be okay for a 17 gpm pressure line, but your low pressure return line should be 1" or -16 so it doesn't have too much back pressure. Pete is right on the valve... it should have a detent set-up on a valve spool if it has a float position.
This post was edited by IH fan at 15:01:27 03/03/13 2 times.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
