Posted by pete 23 on March 03, 2013 at 16:28:29 from (74.47.40.242):
In Reply to: Re: Hydro 86 posted by Erik Dekeyser on March 03, 2013 at 15:59:43:
It is a place to start because you are then eleminating external problems, except in your case you want to be doubly sure the SR lever is fully moving the drive control spool when you move it side to side. There is an adjustment on that to get equal movement both ways. Some times just a loose quadrant will give you a no drive, stop drive or uneven speed control. I would check that part out first. Also, does it go normal in reverse. If it goes faster than normal the hydrostatic motor may be operating in the fast position all the time. The blue line on the quadrant is when the pump has reached it's maximum tilt for higher speed and from that point the motor starts to decrease it's tilt for more speed. A hydro is quite simple in theory, except about a thousand different things happen to them, mostly minor but sometimes hard to pin down.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
