Posted by Janicholson on March 04, 2013 at 16:33:54 from (74.60.94.18):
In Reply to: Farmall C wiring posted by petra79 on March 04, 2013 at 15:33:21:
The link will take you to diagrams. Assuming it is a generator (not an aluminum alternator) The discharge over night is unusual in that the amount of draw would be similar to leaving the ignition, or lights on. and not at all like having a shorted charging system. That usually smokes parts. Method: Use a test light to assure that the generator has no power connected to it with the tractor off. if so it is not the issue. Remove the cover to gain access to the electrical back of amp gauge. Test every terminal with a test light. Both terminals of the amp gauge should be hot. The kill switch (push pull) should have power at the connection to the amp gauge, but none at the ignition side with the button in. and volts at both when the switch is out. The light switch should have power going in, and when off, no power going out. If it has a 4 position light switch, the field connection should be disconnected (VR now has that responsibility). The switch should have voltage going to the lights in D and B. After some testing, get back to us with more detail. Jim
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
