The one wire systems are often restricted in ability to start charging unless spooled to about 2500RPM. Near wide open on a farm tractor with over driven speed on the pulleys is necessary. If you have it wired through the existing regulator Bat and Gen wires, and they are good, it will work that way. If you have additional wires that connect to the ignition from the #1 terminal on the (one wire) alternator, you are probably messing with the already modified regulator. I would not do that. I would only have that one wire from the alt to the (correct) side of the amp meter. I only install the 3 wire systems. They do not stay in a pilot draw (current draining) mode when off, and they start charging just as a car does at first rotation. The link is what I would do. using a stock 10SI. The bypass wire from the starter to the ballast resistor needs to have a diode in it if you use it. That diode (in addition to the one shown) prevents the starter from being in the ignition circuit. The ignition circuit cannot handle turning the starter. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
