If its a ONE WIRE alternator its big output stud wires to the Load (NOT battery/starter) side of the ammeter. Thats where the wire that used to go to BAT on the Voltage Regulator wired, but Id replace it with a new 10 Gauge wire......
If you hooked up Load and Bat and other wires on the old VR wiring you could be backfeeding the coil, I cant say sitting here how you have things wired up now.
Id unhook and not connect any old VR wiring and simply run a wire from the alternators output up to the Load side of the ammeter. Absent any LOAD terminal on an old VR Id wire all loads (lights and ignition etc) to the load side of the ammeter, same side the alternator now wires to. )
If you changed from Pos to Neg ground Id also swap coil wires side to side, you want the coils - to the distributor for Neg ground.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
