d282 has you on the right track.When you have the small plate off the clutch houseing their is a metal pointer that will point to the timeing marks on the flywheel when you turn it to the right spot which will be 8 degrees before top dead center.Ok on the side of the Roosa pump their is a small rectangal plate with two small screws holding it in place.Turn off fuel under tank take the small plate off and rubber gasket.You will see two scribe marks if you have it on No. 1 cylinder if you see one mark turn flywheel one more turn .Then both marks should line up when you are on 8 degree mark on flywheel.If not you have to rotate the whole pump that bolts to the front timeing cover .Three nuts bolt it to the cover loosen them some and turn whole pump to line up the marks when they line up tighten nuts.Then put everything back together.Then bleed pump if it has air in the sustem.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
