I wouldnt try to remove the bolt on the spring because im not sure you will be able to get it back together after its hooked up. You should put the pin in the hole and then hook up the other end into the rock shaft and then adjust the spring so you can get the bolt in. I hope you are hooking up to the backet in the rock shaft and not to the top of the rock shaft because not all the rock shafts have that little bracket on them.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
