Posted by mkirsch on March 15, 2013 at 05:40:50 from (64.80.110.74):
In Reply to: Farmall engine size posted by Maytag on March 14, 2013 at 14:05:47:
Engine size should be cast into the block near where you found the part number. Should say "C123."
You can't tell if the bottom spring is adjusted right until the engine is running. Make sure you've got the throttle linkage adjusted right, then if the engine is surging you can turn that screw in a little bit at a time until it stops. In your case you can probably turn it out some.
If you turn it in too far I think it affects throttle response. You want it set where the governor snaps the throttle open and doesn't "bounce."
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
