Posted by willie in mn on March 19, 2013 at 02:32:27 from (67.142.168.23):
In Reply to: F20 oiling idea posted by Andrew PSencik on March 18, 2013 at 18:19:00:
Just to add to the discussion. Dad had a 31 Regular & 29 10-20. Both had dealer installed kits to do just what you are talking about. Excess oil runs down past pushrods, into the lifter galley,& back to the pan. Both kits were installed somewhere around 1950. That pipe at rear of block is just a vent. Modern systems run the fumes/smoke back through the intake to be burned instead of just dumped into the air. If oil runs out there, the internal drain passages are plugged up or rings are so worn that there is excess blowby. The 3 petcocks- if oil dripped from the top one pan is full. If it drips out of second petcock, okay to run. If running distillate would drain to lower petcock & refill to top one. This was to drain off the unburned fuel that worked its way past the rings. Forgot the number of hours this was recommemded. If running gas it wasn't required. Willie
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
