Re: Farmall 826 Hub
Posted by pete 23 on March 22, 2013 at 10:24:03 from (74.47.40.242):
In Reply to: Re: Farmall 826 Hub posted by mkirsch on March 22, 2013 at 05:42:11:
Good advice with either type wheel. If wedge lock, which I doubt a new wedge may fix problem also. Thing to look at also is see if the rounded part of wheel is touching the axle. It should not as this prevents solid contact on the flats of the axle. A shim will solve that problem or some machining to the hub will also. M&W dual hubs were bad for that. Guy had two men on about and 8 foot bar, still walked. I showed him what to look for , he had them machined and just normal tightening kept them in place. Had several IH wheels with that same problem.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
