Posted by Nathan Rigg on March 23, 2013 at 18:58:54 from (71.51.101.68):
I bought a farmall H really cheap. Metal is straight and in good shape. It was running and transmission and all seemed fine. I was thinking it sounded sort of like a johnny popper and smoked just a tiny bit of oil. Well It's basically running on two cylinders after an inspection. First thing I did was checked the plugs which needed replaced. The 2nd cylinder problem was the plug wire needed replaced. The 1st cylinder after pulling the valve cover I noticed the exhaust valve is stuck open. So much so that the rocker arm is off of the push rod. What is the most likely cause of this? I know this tractor was sitting for quiet a while before the guy I got it from got it running. Is it just stuck from sitting? I was thinking of pulling the head and spraying some pb blaster down the valve guide and using a mallet to pound the valve back in and hoping it doesn't stick when I put it back on. Or do I need a valve job after this? Also is there any chance of a bent valve on these engines if stuck open or is there plenty of clearance? Thanks
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
