Posted by robgIN on March 26, 2013 at 15:30:28 from (70.224.35.32):
In Reply to: F20 timing. posted by Andrew Psencik on March 26, 2013 at 14:02:52:
sounds like you could have a carb problem too. Setting valves won't change your spark timing. Make sure your mag trips just after top dead center and then leave it alone. If you still have the problem, check valve lash and make sure none of them are sticking. If that doesn't eliminate it, make sure you have good plug wires and plugs and the cap is dry and not cracked. These old girls usually run really rich at idle, and if you lean the carb out to make it idle nice and smooth you will create the problem you describe, because every time you give it throttle or the governor does it is too lean and will cause a misfire. 3 1/2 turns out on the main jet is full rich and if you are much less than 2 you are probably too lean.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
