Several possible realities (you choose) Over filling the radiator. It needs to be about 1/2 the way from the cores to the neck when filled. If filled to the neck it will expand as it warms and run out of the overflow. This gives the impression that the system is broken.
It does have an issue (possibly a cracked head or head gasket) compression check and combustion gasses in the radiator check (Kit from NAPA) if it blows coolant.
Assure the coolant is circulating when the tractor is running with the proper coolant level. Look into the radiator and feel the coolant temp to assure it is circulating. Using a infared temp gun is easiest.
The gasket should be replaced. it keeps the spacing correct on the impeller. Making one is OK if the correct thickness is purchased. Careful tapping with a pall peen hammer wil cut a new gasket (hold the paper steady) Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
