Posted by pete 23 on April 01, 2013 at 10:08:33 from (74.47.40.242):
In Reply to: 706 trouble posted by BillyH71 on April 01, 2013 at 06:37:39:
If you have reverse and no forward speeds, I also think the high low shift rail has broke. Take the front wheel drive cover off left side , under clutch pedal. There you will see the reverse shift shaft and fork. Now look up inside to center of tractor top shaft. Move shift lever to high and low range. You should be able to see the range fork move back and forth. I bet it won't move. You don't need a split but you need to remove range trans cover, third arm link cover in rear and with a long arm you can reach that rail over top of differential and pull remainder out. New one can be installed from there also. I use stiff rubber or plastic hose and put rail in that and fish around until you hit the hole. Not an uncommon problem.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
