Re: Cold manifold???
Posted by Janicholson on April 01, 2013 at 16:12:03 from (74.60.94.18):
In Reply to: Cold manifold??? posted by Elvin Frank on April 01, 2013 at 15:47:05:
Propane evaporates in above zero weather and needs no Heat. Gasoline needs a bit more heat in moderate weather to 50 degrees or so especially when high humidity can make frost both on, and inside the carb and manifold. Keeping the air cool or cold, makes it more dense, and thus more of it. this makes more power (assuming good vaporization of the gasoline). Were it mine, I would put an exhaust "heat stove" on it for cold operation feeding warmed air into the air cleaner. Carbureted cars of the 70s and later had them on the exhaust manifold with a tube to the intake snorkel. Almost all piston and carb based airplanes have them to prevent carb icing. A stove pipe with standoffs around the muffler, with a flex pipe to the intake where the pre cleaner attaches, works well, and can be removed in the warmer drier weather.
That manifold will make a bit more power. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
