If the conversion was a generator, and not an alternator, the polarity could be either negative ground or positive. If it is chargine and the battery voltage is at 14 or so volts it is OK grounded as is. If it is a generator, and not charging follow John Ts charging system procedure to set the system correctly. If it is an alternator it is 99.8 % negative ground. The coil should match the battery ground. Negative to distributor with negative ground.
Point gap is .020 on the high point of a distributor cam lobe. (turn engine by hand to get there)
A coil that says on its documentation that it needs no external resistor needs none. a coil that says "use with external resistor does need one. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
