Posted by Nebraska Kirk on April 04, 2013 at 18:17:10 from (207.91.4.159):
In Reply to: Flywheel posted by slowfolk on April 04, 2013 at 06:04:18:
You will need a special tool to pull the flywheel. Unless you have the tools to pull and install the flywheel, I would first try to remove the bolts without pulling the flywheel. Pulling and installing the flywheel without the right tools is a pain, trust me, I have tried....
First of all, if you can't grip the broken bolt with a visegrip, try welding a nut to it. The heat from welding will help loosen the rust bond and then you can get a wrench on it. Heat the flywheel around the bolt with a torch, don't worry, the heat will not hurt the flywheel. Let it cool down some and then squirt some oil on the bolt, the heat will draw the oil into the threads.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
