Posted by Janicholson on April 06, 2013 at 10:07:23 from (74.60.94.18):
In Reply to: By pass ameter? posted by irwing52 on April 06, 2013 at 08:20:44:
Yes you can. Realize that my answer depends on your capability and understanding of electrical issues. With respect, there is serious danger of fire and smoke if wiring is not correct. If the existing has a non standard component (relay switch) which is not a normal part of the tractor, you must decide if the switch is also bad. If the tractor is 6 volt generator based and positive ground, and if the reason that you are intending to do this is because the amp meter is open (does not conduct electricity) And the tractor is not suffering meltdowns in the wiring, just the amp meter is bad, just jump between the amp meter posts with a #10 piece of copper wire (bare is OK) This should just duplicate the current flow to the battery and be fine. This assumes the Relay switch is good. Do not short the jumper wire to the amp meter mounting bracket. If the tractor is Alternator equipped 12v. negative ground, the same jumper might be just fine. If the lights must work while you are waiting for parts, the supply wire to the lights switch should go through a fuse (15amp) then to the battery side of the existing amp gauge. A new wire to provide power to the ignition coil (assumes points and coil ignition, not Magneto.) can be attached to that same supply side amp meter post run through a toggle switch, then to the coil (or ballast resistor if so equipped) If you feel there is an issue with other components in the electrical system, all suggestions are void. Unless you are confident in the ways of electrons, 500 amps will make a mess. Jim
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
