Re: Farmall 560 pto
Posted by pete 23 on April 14, 2013 at 11:04:54 from (74.47.40.242):
In Reply to: Farmall 560 pto posted by Busted on April 14, 2013 at 07:31:28:
Some drag is normal when cold. Should be able to adjust the rod to get good tension on brake and stop it. The over center clutch is latest style, early ones used planetery same as a 450 etc. You probably have worn keyways in operating shaft, worn overcenter mechanism inside or warped discs. You could also try changing the oil in unit to hy-tran as the old oil gets really thick and full of gunk. Only hold a short quart.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
