Posted by Bob M on April 19, 2013 at 17:06:54 from (67.240.171.136):
In Reply to: Farmall 806 wiring posted by Mark Nafziger on April 19, 2013 at 13:33:51:
Mark - The alternator light will not work with a 1-wire alternator. (The purpose of one of the auxiliary wires on a 3-wire alternator is control the warning light). So if you want to keep an eye on the electrical system best to install a voltmeter in the dash.
The oil light should be straightforward. The circuit runs from a switched pole on the ignition switch (IGN or ACC) to the dash light then to the pressure switch.
To test, with the ignition "on" ground the terminal at the pressure switch. If the oil light comes on the pressure switch is bad. But if the light stays dark, problem is in the wiring or the dash lamp itself.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
