SMTA steering adjustment
Posted by Dan on November 16, 2000 at 09:48:36 from (12.18.160.70):
What is the proper way to adjust loose steering on an SMTA? When I fist got it it had a lot of play in the wheel. The steering sharft moved in and out of the gearbox when turned. I tightened up the nut on the end of the steerng shaft past the worm gear. Also slightly tightened the nut on top of the round gear as it would rais up slightly when pressure was put on it. I notice that there are 2 locking colars on the steering shaft up near the front support, on on each side of the support each separated from the support by an inch or 2. I am wondering if I should have stopped the end play by moving the colars in instead of tighting up on worm gear bearing. Steering doesn't bind or turn unusually hard. Have a service manual for this outfit but don't see anything about steering in it.
Post A Followup
: Re: SMTA steering adjustment
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
