Re: C hydraulic leak
Posted by Rick Remmert on April 23, 2013 at 20:41:16 from (68.103.4.23):
In Reply to: Re: C hydraulic leak posted by kevin in Minnesota on April 23, 2013 at 19:47:17:
Go back and look in the archives under Super C touch control overhaul. I just did mine back in February. I posted pictures as I did it, so you can see what has to be done on one. You will need a parts drawing of it to see the parts. I think it is o-ring #34 that you have leaking. It does not show the 2 spools in the drawings with the exception of the very end of one of them. I debated if you can just pull the spool out and change the o-ring or not. I elected to remove the whole unit from the tractor and replace all the seals. Also repainted it while it was out. A word of caution, with the arms removed off the front, the unit still weights over a 100 lbs.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
