Simple test ground the field if that makes it charge the reg is bad if it doesent charge the gen is bad this will work if ALL componets have a ground. If you have a volt meter check the voltage at the batt term on the reg should read batt volts. When the motor is running it should read 7.2 or so. Using OHM meter ALL componets tshould have ground to the battery. Does the ammeter show discharge with the lite on meter can also be bad.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
