Water in oil now??
Posted by Grabatire on April 26, 2013 at 21:20:50 from (216.238.225.102):
Changed the head on a 1953 WD9 because the original was cracked. Had the replacement head checked and resurfaced. Now there is water getting in the oil. That didn't appear to be the case with the cracked head still on the engine.
I notice water seeping out above the rear engine mounting plate so I suspect an expansion plug has rusted through on the back of the block. Is there any way that water can get back into the crankcase from that area other than the rear main seal or perhaps past the expansion plug at the rear of the camshaft?
There is no sign of a faulty rear main seal either.
I seen the engine run before the old head was removed, but I hadn't noticed the water coming from the rear. It probably was, I just didn't notice it.
The engine was extremely rusty inside the water jacket. In fact the water baffles were completely destroyed and there was an inch and a half of sediment in the bottom. I hope the block didn't rust through into the crankcase!!
The engine is coming out tomorrow to deal with the leak at the rear. Is there anything I should be looking for other than what I've mentioned above?
Dave.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
