Posted by bmagee on May 04, 2013 at 18:19:29 from (50.90.101.61):
Need some advice - while plowing with my 2-bottom after an hour, it started missing out. First thing I thought was condenser. I changed points and condenser. It started again about a half an hour after plowing again. I then changed coil, new plugs, checked all wires (swapped out). I even changed gas filter.
Then when started ran great until you opened up the throttle then missed out. I bumped the timing a little and it then ran great.
I went back out and it ran great under load or when plowing, but when I lifted plow out of ground and no load, it would miss out. Did I advance timing too much or what???
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
