Just jack it up and see if it turn ok then. If so, you can forget spindles and thrust bearings. May be as simple as the o-ring on the power steering relief valve or valve it self. Just pull bottom rear plug on mcv and if o-ring is shot the relief valve will fall out. If not, run starter a few seconds and blow it out. Easy to see if adjusting screw has unscrewed or valve is leaking. What is your red light doing when you steer. Should not come one, of course it has to be working like comes on when switch on, not running.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
