Re: H carb kits
Posted by FBH44 on May 13, 2013 at 19:08:46 from (64.85.215.223):
In Reply to: H carb kits posted by BigDanT on May 13, 2013 at 17:25:36:
I"ll post my carb tuning procedure, it may help;
Make sure the float isn’t sticking or touching the insides of the float chamber. Some previous advice was to use a Dremel tool and smooth the insides of the float chamber so it doesn’t rub or touch. Pretty important. Set the float so the top of it rests 1 27/32" above the flat surface of the float chamber.
Initial settings are as follows to get it started;
Main fuel adjusting screw, big screw facing down at an angle, towards the rear, at the bottom of the carb; 2 1/2 to 3 turns open. This main screw turns clock-wise for leaner mixture.
Idle fuel-mixture screw, smaller screw facing forwards, on upper left-hand side of carb; 1 to 1 1/2 turns open. This idle screw turns counter-clockwise for leaner.
Idle speed screw, faces outboard, at the top of the carb; set for 450 rpm, and make sure the governor correctly engages the slot.
Final settings are determined as follows;
Get the engine warmed up, and idling.
Turn OUT the idle fuel-mixture screw until rough running, then turn in until it idles smooth. (Mine is set at 1 turn open.)
Rev it up, wide open, warmed up, then turn the main fuel adjusting screw IN until rough, then out til smooth, then 1/4 turn to 1/2 turn further out. (Mine sits at 1 turn open. Other advice has been to set it at 2 1/2 turns open for pulling implements.)
Should rev up smoothly and evenly.
Too Lean = stumble, sputter, damaged melted plugs.
Correct = tan plugs.
Too Rich = back smoke, black sooty plugs.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
