could be a couple of things from what you describe,are your hoses long enough to switch them from the bucket side to the loader side of the valves,if so change them and see if the problem moves to the bucket if so check the valve spool for proper travel,if travel is correct the valve could have internal damage which is uncommon,if switching valves has the same results as before then one or both lift cylinders is leaking internally a common problem,most of the time it is piston sealing rings damaged or worn out,but pistons will crack,cylinders will score ect. neighbor had the valves repaired on his mf industrial tractor it done the same thing yours is doing,the shop that built the loader spool up didn't machine the end groove back to it's original size was the problem
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
