First of all it can be done at home. First rule of anything to do with pumps is it's got to be clean. There are two o-rings on each of those (throttle and stop) shafts, you'll also need a gasket to replace the one under the pump cover. If I remember correctly there is a spring that has to be disconnect as you lift the cover off, hopefully someone else can chime in with a picture. Good luck, Sam
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
