Well said. They go round and round on this subject on the Ford N board too so I made up a list of reasons to go 12V. *12V spins your engine faster and starts it better in all conditions, especially if it is very cold or if the engine has marginal compression. *12V with an alternator is more reliable and uses a solid state VR instead of an old fashioned system of points, coils and electromagnets to regulate the charging voltage. Solid state is better, more accurate, more dependable. *12V is more forgiving of dirty contacts on/in the entire wiring harness. *12v is the industry standard and has been for 50 years. *12v allows you to run sprayer pumps, flashing lights, winches and a host of other modern accessories on your tractor. *12V lights are brighter. *A 12v alternator will easily put out more amps than an old fashioned generator and vr. *An alternator will charge at an idle. Generator generally will not. *A 12v system is safer. For example, Most people know how to jump a 12v negative ground car, truck or tractor. Not many people know how to safely jump a 6v positive ground tractor with a 12V battery without something exploding in their faces or getting themselves run over. *6v requires bigger, harder to find wires and cables throughout the system. *12v batteries are to be found just about anywhere, are cheaper than 6v and are usually maintenance free. * And last but not least, is this your only 6V machine? What kind of battery is in your boat, motorcycle, lawn tractor, RV, your classic car or even your 4 wheeler or snowmobile if you have them? Why have an odd ball battery that can't jump or be jumped by anything else?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
