Well, you can put 134a in the system and it will probably work fine for a year. Since you already have a leak, you will probably end up charging it next year anyway.
There are a few things that are recommended for the conversion.
I work for the company that makes Hot Shot (an R12 replacement) and can tell you that in order to use 134a, you should change the rubber seals and hoses to 134a compatible materials. You should also flush the lines and change the oil to a 134a compatible oil.
Whatever you do, pull a vacuum on the system before you charge it. You will never get the cooling you are looking for with the lines full of non-condensables (air).
If you want to, you can call our technical support line at 1-866-433-TECH and Jamey will help you out. Just tell him Matt told you to call.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
