Posted by Dennis K (WA) on May 23, 2013 at 13:51:06 from (24.21.78.195):
I can't believe this system is whipping me but it is.
Farmall H, 6V positive ground, cutout relay and four position light switch.
Problem is no charge at low setting and cutout points do not close in low setting.
Normal output in hi, 10-15amps warm and as high as 18amp when cold. The third brush is moved up as far as it will go, 3 bar spacing on the commutator and against a stop on the end plate.
Checked grounds with ohm meter;
batt gr to dash screw or switch .1 -.2
batt gr to gen/cutout .4 -.6
F post on gen to switch .1 -.2
This has been this way since restored a few years ago and finally decided to deal with it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
