Posted by rankrank1 on May 25, 2013 at 11:44:17 from (198.228.228.177):
Decided I would throw a timing light on my ole 1951 Farmall h and set it. (I have only an IT manual)
Anyway, I have a question for the distributor area. I understand how to loosen the 2 clamps that hold the distrubuter so it can be rotated to either advance or retard the timing as needed.
My question is: What is the purpose of the adjustment slot that is on the distributor mounting casting where it bolts to the block. These 2 bolts were somewhat loose on my tractor. I have tightened them and set the timing. That said, I am wondering If there is there a procedure where this needs adjusted? Or is that slot there to simply allow for some wiggle room regarding meshing the cam gears upon initial engine assembly (If this is covered in my IT manual then I have not found it yet).
Thanks
This post was edited by rankrank1 at 11:45:29 05/25/13.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
