You should have an engine stand. Then you can turn the engine upside down, although you could do it on a bench. Remove the front pulley. Remove the oil pan. Remove the oil pump. Remove the timing cover, Remove the rear main seal carrier. Check the top of the cylinder liners for a ridge, cut it out if necessary. Remove the piston connecting rods one at a time, notice the numbers that are on the cam side. Keep the piston rods and caps in the same position and bolt them together hand tight. Remove the main bearing caps, taking care to keep them in order and same position. Now, the crankshaft should now lift out. Measure the crankshaft journals at two locations each, 90 degrees apart. If they are in spec, get some Plasti-gauge and measure the bearing clearance between the crank and the old bearings. Any questions? Regards, Charlie
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
