Re: Re: Re: BOB M got a question
Posted by Bob M on November 20, 2000 at 11:51:49 from (192.232.120.194):
In Reply to: Re: Re: BOB M got a question posted by Randy on November 20, 2000 at 09:50:39:
Randy - I agree with your assessment - sounds like either the voltage regulator is bad, or it doesn't have a good ground to the tractor frame. Most likely however it's the former... My advice is to buy a new regulator ($35 - $40). But you can try adjusting it yourself. You'll need an accurate (preferrably a digital) voltmeter. To make the adjustment: 1 - Remove the regulator cover and identify the regulator relay - it's the one whose contacts are held closed by spring tension. Take a piece of emery cloth or a small file and lightly clean the contact points. 2 - Connect the voltmeter across the battery terminals. 3 - Now start the engine and run at max RPM. While observing the voltmeter, gently bend the regulator spring hanger to SLIGHTLY increase the spring tension. The voltmeter reading will increase as spring tension increases. Stop when the meter reads 7.2 to 7.4 volts. 4 - With the motor still running at max RPM and lights OFF, check the ammeter - it should read 15 amps or less. If it reads higher, you've tensioned the regulator spring too tight - adjust it back so the ammeter reads 15 amps. Good luck!
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
