Sounds like a chipped tooth on the constant mess gear and it will not heal it's self . More then likely this was caused by the transmission input bearing getting bumped at some point during a T/A replacement and one roller fell out and got under the gear . When one splits a I H tractor it is vary wise to place a heavy rubber band around the transmission input bearing to hold all the rollers tight when going back together and also be in perfect alignment and NO slamming jerking , pulling together with bolts . If they do not SLIDE together then your not aligned . If it is ONLY the constant mesh gear then your lucky as i have seen the bottom of the transmission busted out from a bearing roller getting under them .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
