Started out as a moisture problem. Had been raining for days, tried to start the tractor and got nothing.
Used a heat gun on the points and inside the cap, got it to start but it ran REALLY rough, 3 cylinders at best and one of them not all the time. Lotta backfiring through the muffler. Seemed to run a little better if I retarded the mag to just short of cutoff. Next morning it wouldn't start at all.
Took the mag off, cleaned and regapped the points, put new wires and plugs in, no change.
Took the mag back off, swapped the condenser, double checked that it was timed correctly (#1 on TDC, verified by checking the valve lash).
Took the carb off, cleaned it (a little crud in the bottom of the bowl, passages all clear, no sign of water, no big issues) verified that it was getting fuel, left the air cleaner connection off for now.
Also checked compression, 90 PSI +/- on all cylinders.
Watched the rocker arms while cranking (electric start) and no sign of stuck valve(s).
Prior to this problem it has been running like a top and starting right up. If I wasn't already bald, I would be from scratching my head.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
